I get an error message stating that there is an incompatiblity issue. Is there a driver available to correct this installation error?
Hello
Welcome to the Autodesk/AutoCAD Forums !
Win Seven is officially supported by Autodesk with ACAD / ACAD LT 2011
but everybody knows that the 2010 is running fine on Win Seven ...
Any other ACAD 200x is not supported on Win Seven (or more) !
If I remember well :
- To support officially Win 8.0 you need an ACAD / ACAD LT 2013 + SP 2
- To support officially Win 8.1 you need an ACAD / ACAD LT 2014 + SP 1
On Win Seven/8.0/8.1, you have to try the Win XP Compatible Mode to run an OLD ACAD 32 bits !
Or you can use (not free) the Longbow software ... http://www.longbowsoftware.com/
Patrice BRAUD
you can try running in combatibility mode but no gurantee this will work
2006 came out years before Windows 8 did
so expect to run into other issues if you get this to work
DarrenP
