AutoCAD LT General Discussion
Member
jensenff
Message 1 of 9 (1,753 Views)
can autocad lt reduce the size of a drawing
1753 Views, 8 Replies
01-25-2007 03:17 AM
I have some products that I make that a customer has asked if it would be possible to have them reduced by 50% is there any way anyone knows how I can do this quickly without having to draw them again.
Active Contributor
ali_b
Message 2 of 9 (1,753 Views)
Re: can autocad lt reduce the size of a drawing
01-25-2007 03:33 AM in reply to: jensenff
you could always try the SCALE command, maybe the clue is in the name.
*Gary D'Arcy
Message 3 of 9 (1,753 Views)
01-25-2007 04:17 AM in reply to: jensenff
ali_b
That makes as much sense as infinity/2
Be Noice!
Regards Gary.
wrote in message news:5463217@discussion.autodesk.com...
you could always try the SCALE command, maybe the clue is in the name. Message was edited by: Discussion Admin
Member
jensenff
Message 4 of 9 (1,753 Views)
01-25-2007 04:47 AM in reply to: jensenff
Gosh arn't you clever, ... tried that first but will only accept positive values and scales up in size I do not know how to scale down!! which is why i am asking the question.
*Expert Elite*
Charles_Shade
Message 5 of 9 (1,753 Views)
01-25-2007 04:58 AM in reply to: jensenff
.9 would be pointless and imperceptible
.8 is to fit a little better than .9
.7 is just wierd
.6 would be a little larger than .5
.5 would be half
.4 would be .4
.3 would be 1/3
.2 would be one fifth
.1 would be one tenth
Good Luck, see the one in the middle (1/2). More than one
way to whack a cat.
regards,
cshade
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
jensenff
Message 6 of 9 (1,753 Views)
01-25-2007 05:46 AM in reply to: jensenff
fantastic will give it a go thank you very much indeed!!!
Member
jensenff
Message 7 of 9 (1,753 Views)
01-25-2007 05:51 AM in reply to: jensenff
Once again thank you, made life a lot easier. It worked perfectly, I owe you one.
cheers
*Expert Elite*
Charles_Shade
Message 8 of 9 (1,753 Views)
01-25-2007 05:54 AM in reply to: jensenff
Young's Oatmeal Stout in a can
regards,
cshade
Member
jensenff
Message 9 of 9 (1,753 Views)
01-25-2007 11:24 AM in reply to: jensenff
just tell me where to send it, its yours
cheers
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
