Solved by Emmsleys. Go to Solution.
Solved by Charles_Shade. Go to Solution.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
@Anonymous wrote:
I have some products that I make that a customer has asked if it would be possible to have them reduced by 50% is there any way anyone knows how I can do this quickly without having to draw them again.
Hi @Anonymous,
Welcome to the Autodesk Community.
If your files have been worked on by multiple users and in different releases I normally recommend cleaning up your file. After running the below steps Iʻve seen a lot of files decrease in size in a noticeable difference.
After cleaning up the file you can also use the WBLOCK command to export the specific information that you would want to send to a client or a co-worker. Let me know if that helps with your question.
@Anonymous
Were you able to try anything suggested in the thread?
