Salve, ho un PC sul quale è installato Autocad 2010 italiano, il prodotto è attivato ma adesso ho bisogno di sostituire il pc perché obsoleto.
quale procedura devo seguire per trasferire la licenza da un pc all'altro?
grazie
Do you have the disks?
If this is only a second (or third) install then all you will need to do is install the software and activate.
Autodesk recognizes that we all have to reinstall from time to time and does not disallow this.
If there is an issue with the activation then complete the install and follow the advice for using the LTU from Help to the new install.
Create a copy of you Customized CUI and do not uninstall the existing software until you get the new up and running to your satisfaction.
If you do not have the disks you will need to follow a different path to get the software.
Autodesk Media Request:
http://autodeskdocandmedia.com/
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
thank for your post
I have installed and activated autocad on the new computer right now.
need to uninstall the version of autocad from my old computer?
