I am trying to verify the actual area of a floor plan however when I "list" the polyline of the floor plan, I am getting two different figure when opened in Autocad 2012 and LT 2011. For instance, the area calculated in autocad 2012 is 900sqm vs LT 2011 is 850sqm.
It is only for this particular file that has this discrepancy. Other files I have tried gave the same area between the two versions.
We have the setting setup as the same in terms of units etc.
Help.
Welcome to the Forums
It sounds like a rounding problem. Can you post the offending drawing so we can take a look at it?
Howard Walker
I have tried verifying the area with autocad 2012, 2013, 2014 and the area through all these versions are the same.
When I verify using autocad LT 2011 the area is different.
the file can be downloaded thru this link:
Sorry the file is quite large even though it is just a polyline (i have tried audit, purge and even removed the reg)
thanks.
There must be a setting rounding problem in your LT2011 somewhere. I've just loaded the file in LT2012 and LT2008 and get the 882.91 sqm.
Edit the field your using in LT2011 and don't forget to do a drawing REGEN as well. Your field might update
Howard Walker
