If it is a block you use all the time, place it in a folder that is part of
the AutoCAD search path (like your standard symbols folder for example),
then create a simple toolbar macro like this:
^C^C_-insert;MYBLOCK
If you need to automate the process even further, you can predefine a
standard insertion location if you want, run through the Insert options
quickly, or even set scale and rotation if you want:
^C^C_-insert;MYBLOCK;\;;\
or
^C^C_-insert;MYBLOCK;_sc;$M=$(*,$(getvar,dimscale),1);\
Dean Saadallah
www.pendean.com
"carlslist" wrote in message
news:f07d3f6.0@WebX.maYIadrTaRb...
> if you type in the exact pathname,(drive/folder/etc.)
> you should be able to write a tool box that will load
> your block. it should look something like: insert; block,
> pathname; pick point;(and what ever you want from there), don't be shy
with what you type in, just keep experimenting until you get what you want
and check the help menu for the precise syntax for; commands, returns, and
pick points. i think it will take a little time but it should work
> just fine. "autocad lt" is a little bit more fragile than full "autocad"
but it's close enough when it come to writing tool boxes. good luck, hope
this helps, carl welch.
