AutoCAD LT General Discussion
*Apuli, Rainer
Message 1 of 3 (538 Views)
BUG: How to bind xrefs containing proxy objects?
538 Views, 2 Replies
04-26-2000 02:16 AM
I am trying to bind a drawing that contains "proxy objects". Binding seems
to progress as usually, but suddenly after regeneration an *invalid* line
appears and binding is aborted.
How can I bind this drawing that contains "1 proxy object"? Is this "proxy
object" the reason why this *invalid* line appears and how can i get rid of
such objects to be able to xbind?
-Rainer-
*Support], Keith Sibbert [Autodesk
Message 2 of 3 (538 Views)
Re: BUG: How to bind xrefs containing proxy objects?
04-27-2000 08:00 PM in reply to: *Apuli, Rainer
Rainer,
*Invalid* is normally returned if there is some kind of problem with the name
or path. Press the F2 key to open the text window and the complete error
should be displayed.
Keith Sibbert
PSG Product Support, Americas
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
> -Rainer-
*Apuli, Rainer
Message 3 of 3 (538 Views)
Re:
04-28-2000 04:19 AM in reply to: *Apuli, Rainer
Nop! Only *invalid* there. Name and path are ok. Dialog box "Proxy
information" opens after *invalid* and xbind is interrupted.
-Rainer-
