Is there a way to break lines/arcs using the "Break at Point" command (or something simialr) to break lines/arcs along the length of a poly line? I have a drawing where I neeed to break multiple entities that are cut by a poly line, and using the break to point command yeilds the best result, however this requires me to go back to the ribbon every time to specify that I want to break at a point, if I just try repeat last command, it goes to the normal Break shortcut, which then requires me to specify F for respecifying the first point, and then select that point again to ensure that there is no gap in the line. This is OK for one or two lines, but where you have hundreds of lines that need to be broken, it becomes a laborious process. I would think that there would be some shortcut or command that could do this, is there, if so how do I access this?
-Mark
Solved by pendean. Go to Solution.
There is also a "Break at Point" command set built into LT. I have it on a toolbar, this is what it looks like (LT did it not me)
^C^C_break \_f \@
And every time I hit return for previous command it does break at point again.
Howard Walker
