Hi all, I need a bit of help before I make a costly mistake!
Does anyone know if Autocad LT will accept Autodesk Vehicle Tracking and Line Design Pro?
And am I right in thinking the main difference with LT is that you can't do any 3D work.
its more than that: http://www.autodesk.com/products/autocad-lt/compare/compare-products
DarrenP
OP AutoCAD LT will do wireframe 3D, and if you give a closed polyline a thickness you end up with a pseudo-3D hollow shape that appears to be a straight extrusion. LT even has crude shading. You can't create 3D objects such as spheres, nor can you do any decent rendering. LT does open 3D dwg files however, and you can copy in 3D objects from a file created in full AutoCAD.
