AutoCAD LT General Discussion
*Ernst, Lyndon
Message 1 of 7 (1,227 Views)
Blocks not plotting
1227 Views, 6 Replies
12-30-1999 12:24 PM
I am using a non-color dependant plotstyle and no matter what plotstyle I
use I cannot get blocks to plot. Any ideas?
*Support, Autodesk
Message 2 of 7 (1,227 Views)
Re: Blocks not plotting
12-30-1999 10:28 PM in reply to: *Ernst, Lyndon
Are all of the blocks on on the same layer and is the layer set as
printable? Do the blocks show in a full preview? Are all of the block
insertions the same block or different ones?
Keith Sibbert
PSG Product Support, Americas
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
*Ernst, Lyndon
Message 3 of 7 (1,227 Views)
Re:
01-03-2000 10:05 AM in reply to: *Ernst, Lyndon
There are several blocks are on different layers and the layers are
printable. Exploded blocks on the same layers print. The blocks do not
show in full preview, other items do not show either. I have yet to figure
that one out, not showing on the full preview does not bother me as much as
not printing.
Keith Sibbert (Autodesk Support) wrote in
message news:386C4D0B.B7934D3D@autodesk.com...
> Keith Sibbert
I
*Hurley, Shaan
Message 4 of 7 (1,227 Views)
Re:
01-03-2000 10:09 AM in reply to: *Ernst, Lyndon
Lyndon,
What about without any plot style in use? Could you post the drawing to the
customer files discussion group or email it to me? My guess is the blocks
are on a non plotting layer or pens and when you explode the blocks they
then revert to a plotting layer. What driver/device?
Sincerely,
Shaan Hurley
Autodesk Beta Programs
http://betaprograms.autodesk.com
Lyndon Ernst wrote in message
news:84qod4$m0h16@adesknews2.autodesk.com...
figure
as
> not printing.
in
> > Keith Sibbert
plotstyle
> I
*Hurley, Shaan
Message 5 of 7 (1,227 Views)
01-03-2000 12:15 PM in reply to: *Ernst, Lyndon
Lyndon,
Please only post file attachments to the customer files discussion group in
the future. There should be no difference in inserting blocks in AutoCAD LT
2000 and prior releases other than how you have your plot styles configured
and the lineweights. To confirm insert a block drawn on layer 0 (white and
continuous) and insert it in a new drawing on layer1 (yellow and dashed) and
it will take on the layer attributes of layer1 not layer 0 so it will
display yellow with a dashed linetype. Could you have accidentally inserted
the blocks on layer 0? I would also suggest in the future using color
dependant plot styles as that may be what else may be confusing you. You did
not include your PC3 file and STB plot styles so I am not sure what you have
going on there as well but again color dependant CTB would be the easiest
route unless you have a specific reason for named plot style mode.
Helpful links:
AutoCAD® LT Product Support main page:
http://www.autodesk.com/support/acadlt/index.htm
General AutoCAD® LT 2000 Tech. Solutions:
http://www.autodesk.com/support/acadlt/lt2000.htm
AutoCAD LT 2000 Support Assistance
http://www.autodesk.com/support/acadlt/asalt.htm
Sincerely,
Shaan Hurley
news:84qt10$m1b25@adesknews2.autodesk.com...
> You hit on the problem. In previous versions of AutoCad blocks were
created
> on layer 0 and when brought in as a block they took on the characteristics
> of the layer they were brought in on. Now apparently they still refer
back
> to their original layer and while taking on the color etc.. of the layer
> they are brought into they still use the original layer for plotting
> instructions.
> I just removed the no plot instruction from layer 0, which by the way is
the
> standard for LT2000, and the blocks plotted. They were created on layer 0
> and brought into layer A-Eqpm, or some other layer, they appear to be on
> that layer when you pick properties, but they plot according to layer 0
> plotting instructions.
> I am plotting to the latest Windows print driver for an HP Deskjet 1120C.
> Shaan Hurley wrote in message
> news:84qot1$m0g24@adesknews2.autodesk.com...
> > Lyndon,
> the
blocks
> > Sincerely,
> > Shaan Hurley
not
> > figure
much
> > as
> > > not printing.
wrote
> > in
block
> > > > Keith Sibbert
> > plotstyle
> > > I
*Ernst, Lyndon
Message 6 of 7 (1,227 Views)
Re:
01-03-2000 02:33 PM in reply to: *Ernst, Lyndon
Isn't you responce sort of like saying please return to using LT98? I am
assuming that AutoCad is moving away from color dependant plotting, which I
agree with having used software that is not color dependant. I wish to use
the STB format because I see advantages to using this format and as I told
you in my previous note I have already done what you suggested with the
installation of blocks. Look at the file and you will see that is the case.
I am emailing you my STB file.
I look forward to a solution to my issue.
news:84r09e$m0j32@adesknews2.autodesk.com...
> Lyndon,
in
LT
configured
and
and
inserted
did
have
> Helpful links:
> Sincerely,
> Shaan Hurley
> created
characteristics
> back
> > instructions.
> the
0
on
1120C.
> > > Lyndon,
to
> > the
> blocks
they
> > > Sincerely,
> > > Shaan Hurley
> not
> > > figure
> much
> > > as
> > > > not printing.
> wrote
> > > in
> block
> > > > > Keith Sibbert
> > > plotstyle
> > > > I
*Hurley, Shaan
Message 7 of 7 (1,227 Views)
Re:
01-03-2000 03:20 PM in reply to: *Ernst, Lyndon
Lyndon,
No that is not what my response was intended to mean. All I was trying to do
is offer a plotting methodology that was more familiar as many have gotten
confused with Named Plot styles. If you feel comfortable with them by all
means stay with them but they can be confusing at times even to me. Also
since you are emailing and posting hitting me from both sides I will reply
to your email here as well, but please in the future keep the replies and
correspondence with me in one place. Sorry but without more detailed steps
to reproduce this problem I cannot commit anymore of my time.
I am unable to reproduce your problem of inserting blocks drawn on layer 0
not taking on the properties of the inserted layer with your drawing and
plot style. As a suggestion on your drawing to get a WYSIWYG (What You See
Is What You Get) on your Layout right-click on the Layout tab then select
Page Setup. Now in the Pagesetup dialog select the Plot Device Tab and then
check the option to "display plot styles" then choose OK. Now your Layout
will be a WYSIWYG view.
Sincerely,
Shaan Hurley (not Product Support)
news:84r84q$nsc7@adesknews2.autodesk.com...
I
use
case.
> > Lyndon,
> in
> LT
> configured
> and
> and
> inserted
> did
> have
easiest
> > Helpful links:
> > Sincerely,
> > Shaan Hurley
> > created
> characteristics
> > back
layer
> > > instructions.
is
> > the
layer
> 0
> on
0
> 1120C.
> > > > Lyndon,
> to
> > > the
> > blocks
> they
> > > > Sincerely,
> > > > Shaan Hurley
are
do
> > not
to
> > > > figure
as
> > much
> > > > as
> > > > > not printing.
> > wrote
> > > > in
as
> > block
> > > > > > Keith Sibbert
> > > > plotstyle
> > > > > I
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
