I just installed LT2013 and migratet my settings from LT2008.
Doubleclicking on a blok openes the block editor in LT2008, but not in LT2013.
In LT2008, the main cui file was acadlt.cui. And in this file the "block - double click" action was specified. And it worked in LT2008. I have my own cui-file which not contains any doubleclick-actions.
In LT2013, after migration from LT2008, the mail cui file is now my own cui-file (which not contains any doubleclick actions). Is this why it doesnt work ?
I have tryed to copy a doubleclickaction from acadlt.cui to "my own cui-file". And now it works.
Is this because "my " cui file now is the main cui file ? Why is "my" cui file the main cui file after migration ? is there a way to change, so acadlt.cui becomes the main cui file ?
If not, is there a way to transfer alle settings from acadlt.cui to "my" cui file ? I know i can do this one action of a time in "transfer".
Solved by thorkil50. Go to Solution.
Hello from France
If you try with the keyboard the "good old" command : REFEDIT
and then Click on the Block or XREF ...
What's happen ? Is it OK ?
I suppose that the migration of the Interface of your old ACAD LT 2008
has completely "disturb" the LT 2013 Interface !?
Migrating parameters from an old ACAD/ACAD LT is a "fault" (my opinion)
Bye, Pat
Patrice BRAUD
