AutoCAD LT Forum
Block Definition
7 REPLIES 7
Message 1 of 8
millerew17
448 Views, 7 Replies
Block Definition
I'm looking for advice on the best way to go with the "Behavior" settings for creating my "Window and Door Tag" blocks ( Hexagon with Letters & Circles with Numbers). Annotative with Match Block Orientation...... Or... Scale Uniformly ??
7 REPLIES 7
Message 2 of 8
pendean
in reply to: millerew17
A Dynamic Blosk that's also Annotative should do it.
Message 3 of 8
millerew17
in reply to: pendean
So I do want to click the Annotative & match block.... box in the Block Definition dialog box?
Message 4 of 8
pendean
That's a start: you need to turn it into a dynamic block too with BEDIT command and add custom parameters.
Create a DWG file, drop your symbol into it and share it in the dynamic blocks forum and ask the folks over there to help you create what you want: http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
Message 5 of 8
millerew17
Many Thanks again...Dean
Message 6 of 8
millerew17
Hey Pendean, I hope it's OK to tag another follow up question to this earlier post.
Is there a way to edit/change the behavior of blocks that I created that were non-annotative to Annotative? I had a bunch made before we connected on this post that I'd like to correct without redoing them all.
Message 7 of 8
pendean
This classic blog lost covers the basics: http://thecadgeek.com/blog/2007/05/making-blocks-annotative/
Message 8 of 8
millerew17
”Boost
