AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Block Attributes with variables?
3 REPLIES 3
gborsos06
478 Views, 3 Replies
Using ACAD2014LT.  I want to use the first variable attribute value as a variable in subsequent attributes in the same block.  This will be extracted and used for tag references in a PLC program.
Along the line, i know I can change the enclosed character ( ' ), but can I remove it?
3 REPLIES 3
Charles_Shade
in reply to: gborsos06
Fields are the way to do this but I do not think the Block will properly update unless a Dynamic Action is applied and run on it.
gborsos06
in reply to: Charles_Shade
Fields will be tedious.  I need about 1000!
pendean
One unique block with one unique fixed variable and an adjacent editable variable for your 'subsequent' needs is another option.
If you mean or need more, time to post sample DWGs with sample blocks and notes for others to review in more detail.
”Boost
