Using ACAD2014LT. I want to use the first variable attribute value as a variable in subsequent attributes in the same block. This will be extracted and used for tag references in a PLC program.
Along the line, i know I can change the enclosed character ( ' ), but can I remove it?
Fields are the way to do this but I do not think the Block will properly update unless a Dynamic Action is applied and run on it.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
