AutoCAD LT Forum
Binding xref's
6 REPLIES 6
931 Views, 6 Replies
Binding xref's
I'm using 2009LT.  I'm archiving old jobs, and am binding all the xref's.  Is there a keyboard command that will allow me to do this without having to use my mouse? (dislocated index finger on my right hand)
6 REPLIES 6
Charles_Shade
Look around and see if that can be called from a Macro or Script.
Someone may have created one and posted it somewhere. Google too.
Johneng
-XREF command will give you command line prompts. You can also try this untested macro.
^C^C-XREF;B;*;
in reply to: Johneng
If you just enter the commands as you wrote it, it doesn't work.  However, it you enter -xref then b then *, it will work.  thanks, I can type that one handed.
pendean
The tip posted was a menu macro, as others suggested, to creat a button for this action: it was not a type-at-the-commandline instruction.
Charles_Shade
OP you are correct that the string will not work from the Command Line.
If you place this Macro on a button in the CUI then you will have a one click option for the index finger.
in reply to: Charles_Shade
Ok, wasn't thinking on the lines of a macro, thanks.
”Boost
