HiIhavebeentoldIneedadedicatedquadrographicscardinalaptopforAutocadLT2015toworkisthiscorrect?Ifsoitmeansaveryexpensivelaptop!
Solved by braudpat. Go to Solution.
How much money do you want to spend?
Which part of the world are you in?
What is your favorite brand of computer/laptop?
What are your current PC/Laptop specs, and which OS? And have you actually tried to install LT2015 as a trial to see if there are any issues with it?
Hello
Welcome to the Autodesk/AutoCAD Forums !
Please look a little bit to this Topic :
http://forums.autodesk.com/t5/autocad-2013-2014-2015/autocad-2015-system-requirements/td-p/5265605
Even if you can't create/modify 3D Objects with ACAD LT, I estimate that you need 8 Gb ... maybe more ...
Patrice BRAUD
