AutoCAD LT Forum
Batt insulation hatch?
5 REPLIES 5
5993 Views, 5 Replies
Can someone point me to a site where I can buy a quality HATCH pattern for batt insulation (i.e., the S curves as used in architectural details of walls)? (I have AutoCAD LT 2004 but 2005 is in shipping to me now.) TIA, Paul
5 REPLIES 5
Most likely you can pick them up for free from most AutoCAD shareware websites. Google it. If you want to buy some hatch patterns, you can try http://www.hatchpatterns.com -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Paul, This is an optimised batt insulation hatch. (You can draw any hatch you like with HatchKit). Cut and paste it into your ACAD.PAT file or put it in a text file BATTS.PAT in your support file path. HTH Hugh Adamson Cadro Pty Ltd. *BATTS,Insulation ;--------------------------------------------------------------------------- ---- ; Pattern written by HatchKit Hatch Pattern Editor ; HatchKit (c) Cadro Pty Ltd 1990-2004. ; www.cadro.com.au/hatchkit/ ;--------------------------------------------------------------------------- ---- 18.4349488229,-3,-1,55.656086819,2.52982212813,6.3246,-56.9209532034 288.434948823,-9,19,43.0069761783,2.52982212813,18.974,-44.2715532034 341.565051177,-3,1,7.5894663844,2.52982212813,6.3246,-56.9209532034 71.5650511771,3,1,20.2385770251,2.52982212813,18.974,-44.2715532034
Paul, try this one, I fell foul of the wordwrap gremlin in my previous post. Hugh *BATTS,Insulation ; Pattern written by HatchKit Hatch Pattern Editor ; HatchKit (c) Cadro Pty Ltd 1990-2004. ; www.cadro.com.au/hatchkit/ 18.4349488229,-3,-1,55.656086819,2.52982212813,6.3246,-56.9209532034 288.434948823,-9,19,43.0069761783,2.52982212813,18.974,-44.2715532034 341.565051177,-3,1,7.5894663844,2.52982212813,6.3246,-56.9209532034 71.5650511771,3,1,20.2385770251,2.52982212813,18.974,-44.2715532034
Hugh, Thanks for your reply! I just yesterday received ACLT 2005 and it took me a minute to find the right PAT file into which to put your hatch. When I did, it seems to be what I am looking for, of course, but I am at a loss to know how to control it so that the snaking S pattern fully fills the rectangle without chopping off a bit at the top of bottom or showing more than one pattern. I am a newbie to ACAD and it looks to me like that might be why a "linetype" might be the way to control this type of "hatch". Or am I missing something obvious? Again thanks for your assistance and I will check out your web site. "Hugh Adamson" wrote in message news:4125591f_2@newsprd01... > Paul, > > This is an optimised batt insulation hatch. (You can draw any hatch you like > with HatchKit). > Cut and paste it into your ACAD.PAT file or put it in a text file BATTS.PAT > in your support file path. > > HTH > Hugh Adamson > Cadro Pty Ltd. > > > *BATTS,Insulation > ;--------------------------------------------------------------------------- > ---- > ; Pattern written by HatchKit Hatch Pattern Editor > ; HatchKit (c) Cadro Pty Ltd 1990-2004. > ; www.cadro.com.au/hatchkit/ > ;--------------------------------------------------------------------------- > ---- > 18.4349488229,-3,-1,55.656086819,2.52982212813,6.3246,-56.9209532034 > 288.434948823,-9,19,43.0069761783,2.52982212813,18.974,-44.2715532034 > 341.565051177,-3,1,7.5894663844,2.52982212813,6.3246,-56.9209532034 > 71.5650511771,3,1,20.2385770251,2.52982212813,18.974,-44.2715532034 > >
we do hatch patterns *much* better than we do linetypes, however you may try this: http://www.cadresource.com/library/fonts.html and look for INSUL.ZIP Google on "autocad linetype insulation" for other leads. HTH Hugh Adamson
”Boost
