AutoCAD LT Forum
Batchplot vs ExportPDF
2 REPLIES 2
Zaster
858 Views, 2 Replies
Howdy.  I have recently narrowed an Issue I have with creating PDF drawings from Autocad 2010 LT down to my using the Batchplot feature.
If I batchplot a set of drawings to a PDF, then view the PDF, I get an error saying Adobe "cannot find or create Timesnewromanpsmt font".  Strangely enough, I do not use that font.
However, If I just exportpdf the drawing and open in Adobe, there is no error generated when I view it in Adobe.  What is the difference between the two methods that might cause this, and how can I resolve it?
Thank you!
2 REPLIES 2
pendean
in reply to: Zaster
Change how the dwg to pdf.pc3 file handles fonts: set it to capture all.
PLOTTERMANAGER command inside LT, double-click on it>device settings tab>Custom Properties>Font Handling.
Zaster
in reply to: pendean
I dont know how you know this / figured it out, but it worked like a charm.  Thanks!
”Boost
