AutoCAD LT Forum
bak files are not being created
8 REPLIES 8
Message 1 of 9
theresaramsay
1955 Views, 8 Replies
autocad is not saving backup files automatically, only when i manually save are they updated [defeating the purpose of them].  in my options - open and save - i have my automatic saves set to 3 minutes and am also set to create backup copy with each save.
please help.
thanks
8 REPLIES 8
Message 2 of 9
Holly_Jones
in reply to: theresaramsay
Message 3 of 9
pendean
You relying on autosave to create BAK files? You pretty much have to give up saving and risk losing everything for that to happen.
Say it isn't so... .
Message 4 of 9
theresaramsay
in reply to: Holly_Jones
thanks for that!  i do see some files there.  still wondering why the bak file in the file i'm working on does not update unless i manually save?
@Holly_Jones wrote:
Message 5 of 9
theresaramsay
in reply to: pendean
thanks for your reply but i'm not sure what mean? i'm wondering why my backup files aren't backing up unless i save my drawing - which is useless.
Message 6 of 9
pendean
Autosave in AutoCAD doesn't work like Autosave in MSWord: it's best practice to never rely on it and to get in the habit of manually saving regularly. It's best relied on in case of a crash/recovery type scenario only.
Message 7 of 9
i try to save as often as i remember, however i can go an hour without saving and then when my autocad crashes and i try to retrieve my backup file and it hasn't be updated since my last save or worse the previous day - it's frustrating.  i have worked on many autocad setups before this version / computer and never had this problem.  my coworkers also don't have this problem but can't help. i thought perhaps someone could show be how to fix this issue.
thanks for trying.
Message 8 of 9
Many here have added the Save command to oft used OOTB Commands and custom Macros.
Helps to create that Save without thinking about it.
3 Minutes may be too quick. Try 10 and see if you get better results; though with the Sage advice that has been given, it is better to Save early and often.
Also a SAVE or QSAVE wil reset the backup clock so it is possible to not create a backup during a CAD session.
Message 9 of 9
pendean
After a crash, you need to go to your system temp folder and look for SV$ files with the same name as your DWG file: check the time to ensure it's later than your DWG file, rename the extension, and 95% of the time you will recover more content than a BAK file after a crash.
”Boost
