I am trying to create some balloon callouts using the Mleader option and using block instead of Mtext however I cannot find how to put a background mask in the circle. I would have thought that it would auto mask the circle so it can be placed over objects and still be readable but this does not seem to be the case. I looked through all the style editors and properties but there is no option to add a background mask. I tried creating my own and applying a hatch but it wont place the hatch behind the attribute.
The item bubble for mleader is called _tagcircle. It has no background mask.
Insert an mleader item and explode it, erase the leader and mark the center of the remaining item circle with a line.
CAVEAT: Adobe Acrobat and some printers do not play well with wipeouts.
Others here will suggest using a white color hatch rather than a wipeout, but this works well for me.
[edit]
Do not turn off or freeze the wipeout layer at plot time or it won't mask
[/edit]
HTH
DJ
Excellent, Dr John! I did the same thing a few years back with the hexagon 🙂
