Bonjour j'ai un souci avec un fichier qui s'est mis tout seul en axes XZ et je ne trouve pas de solution pour evenir a XY. ce qui m'ennuie car je ne peux plus bosser dessus. Quelqu'un peut il m'aider?
Not sure I understand what you need to do.
Can you explain the problem again?
Also, seek out braudpat in this Forum. She speaks French and may understand your query better.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
If I understand correctly, either use the command 'UCS' with the option 'FRONT' (you will need to type FRONT) then '_PLAN' with the option 'Current UCS' you can work from there. Or if you want to change the drawing use 'UCS' with the option 'RIGHT' select everything and 'ROTATE' it 90° then 'UCS' 'WORLD'
