AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Autodesk 360 error
5 REPLIES 5
rimutaka
246 Views, 5 Replies
Autodesk 360 error
Recently, an error message appears on my computer " Autodesk 360 error ".
I have checked that a hotfix can solve this problem but this applied only for Autocad 2013 while my one is AUTOCAD LT 2012.
Can someone explain to me how to fix this error?
Thanks in advance
5 REPLIES 5
Charles_Shade
in reply to: rimutaka
Reboot and cross your fingers as the program reloads.
Does Autodesk 360 actually work on a regular basis? Not had that happen to me yet.
Many times a day I receive sychronization errors
The Hotfix in the text says 2013 products but in the right column many more versions are included as being applied to. Give it a try.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21520416&linkID=9240617&siteID=123112
pendean
Do you use Autodesk 360/Cloud services? If not, turn it all off in OPTIONS command's last tab in 2012.
rimutaka
in reply to: pendean
Thanks for prompt reply.
I have checked and can't find hot fix for Autocad LT 2012.
pendean
No fix for 2012
Charles_Shade
Or try to force it.
Click on the Dropdown where your sign-in name is and choose to Sync your settings. This cleared up the error here.
”Boost
