Hi Folks, I have Autocad LT2000 however I havent used it for a long time. I am designing a building and I have problem setting it up for 1/4"=1'-0" scale. I would appreciate it if any of you would give me a deatiled sequence of creating a new
drawing for the above scale. I need step by step instruction. I also would like to use an Architecture D size title block.
I apprecate your help and thank you.
Gabe
From the Command line:
NEW
Select the Architectural Template you want
(done)
Draw your building at 1:1 in Modelspace
Click on a Layout
Add a Viewport if needed at scale 1/4" = 1'. The Scale can be set form the Properties Window
Right click the Layout tab. Choose Page Setup Manager
Choose your Plot Device and Paper size
Set Plot Scale to 1:1
Move your Title Block and Viewport around until it is on the "Paper" shown in the Layout (Paperspace)
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
...and don't forget to lock that viewport!
