AutocadLT is locking up every time I hit save file or try to open a saved file. In order to get out of the program I have to force a restart. I cannot save a file open an existing saved file or print / publish a drawing. Any assistance greatly appreciated.
Hello
Welcome to the Autodesk/AutoCAD Forums !
Q1) Which version of ACAD LT exactly ?
Q2) Which Service/Update Pack already installed ?
Q3) Which Windows ?
Q4) 32 or 64 bits ?
Q5) How much Ram in Gb on your PC ?
Q6) Have you other AutoCAD softwares running OK on the same PC ?
Bye, Pat
Patrice BRAUD
hi Pat, just looking at my responce to your post and it looks very abrupt. So apologies for that I was in a hurray to respond before starting my normal day and without my fill of coffee.
I have made more of an effort to detail the answers to your questions below.
Answers to Q1: It is ACAD LT 2011, fully licenced
Q2: I have not downloaded any updates,
Q3: Win 7 Professional, Last system update 1 month ago
Q4: 64bit,
Q5:16.3GB free space of 149Gb;
and Q6: No other ACAD programs at all, did have a trial edition of 2014 before I got the 2011 but I uninstalled it before uploadingthe 2011.
Thanks again for taking the time to help. Ray
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
More complete .NET fix if you did not go through this procedure:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Hello
I was speaking about the MAIN memory in Gb ! not the hard disk capacity ...
Have you tried to Install your ACAD LT 2011 64 bits with the PC completely disconnected from the Network AND from Internet ?
and to Install AND Run with the Anti-virus & Frewalls DISABLED ??
What is exactly the PC : Dell, HP, Lenovo, Toshiba or XXXX ??
Which graphic card ??
Bye, Pat
Patrice BRAUD
