I'm using Windows 7 and have an issue with a single dwg file, as soon as I push the print button AutoCAD goes to "not responding" and never comes back out of it. I have opened the same dwg file in LT 2012 and it prints without any problems. Also, all my other dwg files from other projects print without error in both 2012 and 2014. Have run an audit (no errors found) and purged all in the dwg and still no luck.
I found a forum on another site that indicated this issue has to do with AECCORE.crx file however was not able to get the fix they recommended to work.
Here the service pack for AutoCAD LT 2014, if the program didn't prompt you to update:
http://usa.autodesk.com/getdoc/id=DL22264544
Check the page setup of the drawing to make sure it is still correct. You might need to recreate the page setup. Is AutoCAD LT 2012 on the same computer as 2014? Dean may be right about a bad settings migration. You can reset the program by clicking Start > All Programs > Autodesk > AutoCAD LT 2014 > Reset Settings To Default. See also if you have acadlt.exe set to run as administrator. We often recommend having it this way. You might have 2012 set but not 2014.
I've just started having this same problem, but Autocad LT 2014 has been running smoothly for a couple of weeks until now.
It doesn't matter which drawing I'm in - as soon as I click 'Plot' the system freezes and never recovers.
Help...............
Hi Martin,
Did you ever get this problem sorted? I'm having the same issue now.
