AutoCAD LT General Discussion
New Member
0 Kudos
Post 1 of 4
AutocadLT 2010 crashes on start-up (even after installing hotfix)
1431 Views, 3 Replies
10-02-2012 01:33 PM
I'm having a constant problem with Autocad 2010LT crashing on startup. After clicking on the AutocadLT 2010 icon the program starts to run, I see the start-up screen, and then everything disappears without any notice or error message.
I have installed service Updates 1 and 2 as well as the "Startup Error and Text Editing Hotfix". Nothing that I have read on the forums seems to fix the problem. I'm running Windows 7 Professional (64-bit). I should also mention that I have been running this version of the software on this computer without any issues for over 1 year before encoutering this problem.
Any suggestions would be greatly appreciated.
370 Kudos
Post 2 of 4
Re: AutocadLT 2010 crashes on start-up (even after installing hotfix)
10-02-2012 01:37 PM in reply to: ZEI2
What changed on your Computer?
And LT 2010 is not designed for Win 7. Did you install under compatability mode?
Is it a 64 bit seat of LT?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
New Member
0 Kudos
Post 3 of 4
10-02-2012 01:52 PM in reply to: Charles_Shade
Thanks for the quick reply Charles (nice house designs BTW).
The only thing that changed is that I installed the new version on Norton Internet Security. I doubt the version of Autocad LT I have is 64 bit, but I can't be sure because it doesn't say so in the box. We originally ran in the software in windows XP on a mac.
I just looked in the Adlm log file, and this is the error message I'm getting:
Reason=Fatal error
ComputerName=ZEI2-THINK
OS=6.1.7601.Service Pack 1 (forum edit: note that Service pack 2 is installed)
File=AdlmIntLicense.cpp,Line=486
VendorID=6 [ADLMPIT]
VendorError=25 [Error has occured while parsing Product Information Table file]
Reason=Fatal error
File=AdlmIntLicense.cpp,Line=487
AdlmIntError=2 [Failed: Internal programming error]
Reason=Fatal error
File=AdlmIntSATSLicense.cpp,Line=958
AdlmIntError=17 [The license was not found]
I found a similar error on the forums and Autodesk's reply was the you need to re-install as soon as you get the "parsing Product Information Table file" error. The problem is that when I do this, the program runs fine for a couple of days, and then I get the error again. I've reinstalled the software about 10 times over the past three weeks.
I'll reinstall and try your suggestion of running it in compatibility mode.
1,605 Kudos
Post 4 of 4
10-02-2012 02:32 PM in reply to: ZEI2
>>>...Norton Internet Security...<<<
That's been known to break AutoCAD for many years now. Uninstall it completely, restore you PC to the day/week before you did that, repair reinstall LT (or remove and reinstall it per Autodesk's guidelines), the test.
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
BTW, 2010 only installs as a 64bit in Win7 64bit, and only 32bit in Windows 32bit: you could not mix and match no matter how hard you tried to do it.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
