The cursor flickers and redraws an awful lot in the 2015LT version.
The visual is wearing me out... I ended up returning to 2014 just to complete the rest of my work for the day... I'll put up with the crashing in windows 8.1
I notice a subtle difference in 2014 to 2015 - a dashed apperature box - any way to turn that off and make it solid, along with the ray that gets drawn when moving objects, and the little Icon next to the cursor that tells me what command I'm in?
Solved by organicmodern. Go to Solution.
Solved by braudpat. Go to Solution.
Not to be a jerk but... I'm expecting a software upgrade, not a hardware upgrade!
Its the exact same system that was running LT2014 as LT2015.
For the record NVDIA Quado FX1700 running with a dell precision 4 core pentium with 32 meg memory
Windows 8.1 - the reason I'be been told to upgrade from lt14 to 15 to avoid crashing.
Tried various acceleration setting with same results. Not really thrilled with the results...
Thank you for the quick reply.
Please note my comment about the cursor rendering as a dotted line vs a solid line. Hoping its an insight for your tech programmers.
Hello from France
Q1) Have you tried to run ACAD LT 2015 WITHOUT "Graphic Hardware Acceleration" ?
Always bad display ? - Very often, it solves this graphic problem !?
Q2) You have a NVidia graphic Card so ...
Is is possible to DISABLE the "NVidia FXAA Anti-Aliasing" feature ?
Please look inside your NVidia Driver or Properties of the NVidia ? Often, it solves this graphic problem !?
Q3) Have you tried to install the latest NVidia driver for YOUR graphic card ?
The 2015 graphic display engine is using some new routines/features with the graphic card drivers !
So a lot of people have strange display problems ...
Patrice BRAUD
The NVIDIA DRIVER was the problem (as supplied by NVIDIA). I recently DOWNLOADED FROM AUTODESK a driver that worked a lot better than the latest driver supplied by NVIDIA. Now I'm getting the clean crisp response that I was after! Woo hoo! No more flicker and running with accelleration on, alias off.
i have autocad 2015 and laptop 16gb,1tb,2gb grafic,core i7.
when ever i m using autocad cursur is flicking with white line .
Need support...
