AutoCAD LT Forum
AutoCAD LT2013 Can this software run on windows 8
5 REPLIES 5
dalesteels
1753 Views, 5 Replies
5 REPLIES 5
DarrenP
in reply to: KateMorricalTowne
it can probably run but its not a supported OS for LT 2013
DarrenP
pendean
in reply to: DarrenP
Some folks are having a hard time just installing it, so "probably run" can be an expensive paperweight option.
david.lau
in reply to: dalesteels
The short answer is no.  However, we will update this solution when it will be.
http://usa.autodesk.com/getdoc/id=TS19048377
This blog post also talks about it as well.
http://upandready.typepad.com/up_and_ready/2012/11/windows-8-support.html
The main issue is that Windows 8 is using a newer version of .NET (4.5) and we install .NET 4 with an Autodesk 2013 product.  The Media and Entertainment products are not using the .NET framework as much so the transition to newer operating systems is not affected by this requisite.
David Lau
david.lau
in reply to: david.lau
”Boost
