After almost 10 good use, I get an error message when starting ACLT, A breakpoing has bee reached. (0x80000003)occured in the application at 0x7c839ac5. The computer then locks up. The only recovery that I have found to work, is to reboot. I tried using the installation CD to A.Repair, B. Reinstall, C Uninstall followed by Install. None works
To what OS and what changed on the Computer to cause the install to fail?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
