AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
autocad lt with a mind of it's own
9 REPLIES 9
Message 1 of 10
sjeggefjes
398 Views, 9 Replies
Hi.
I have a problem with autocad not doing what I want. When trying to draw a line and choose a startingpoint, autocad
desides that this is wrong and start the line in a different place. I've turned of autosnap and autotrack but this dosen't help.
What is it that I've forgot to turn off?
This problem came after a reinstalation of autocadlt 2013
sjeggefjes
9 REPLIES 9
Message 2 of 10
Charles_Shade
in reply to: sjeggefjes
Need new batteries in our mouse perhaps?
Are you entering coordinates and do not have the coords set to World?
Does the line just start somewhere off in space and not where (if you are) mouse clicked?
Message 3 of 10
sjeggefjes
in reply to: Charles_Shade
Hi.
mouse is on cable
coordinate is choosen by mouse klikk and line is starting at the end or corner
of other lines nerby. If I try to draw a line not center on a other line then it jumps to center or
end of that line.
Message 4 of 10
pendean
Is the problem in all files? Or just this one file?
Why did you have to reinstall LT?
Message 5 of 10
sjeggefjes
in reply to: pendean
it happens with all files. "reinstalation" because of computer crash
Message 6 of 10
pendean
If you type OSMODE at the command line, what setting is reported?
Can you post a full screenshot of the AutoCAD Program Window while your cursor is hovering over a line where you intend to click on an endpoint but the center is selected?
Message 7 of 10
sjeggefjes
4133 is the value of osmode. it didn't let me post a print screen
Message 8 of 10
Charles_Shade
Your first post indicated the Object Snap is Off but here you have given the OSMODE Variable number.
Tap F3 (Toggles Osnaps On and Off) and see if that helps. Just want to confirm that no Osnaps are running.
Message 9 of 10
sjeggefjes
Tank you! I knew there was someting simple that I've overseen Smiley Embarassed
Message 10 of 10
Charles_Shade
Look up the OSMODE Variable and change the Bitcode to something that works for you.
The setting on my system is 175. (End, Mid, Cen, Nod, Int, Per)
You may only want NEArest (512)
”Boost
