I am considering puchase an AutoCAD LT subscription. It requires to be connected to the internet each time I log in. I travel quite a bit and am not always connected to the internet. Can I "borrow" my license like I do at work when I am traveling?
no
its only standalone licensing
it looks like your looking at the desktop subscription option
read this
Does the software included with Desktop Subscription require an internet connection to work?
The desktop software will work offline for up to 14 days, at which point you must connect to the Internet to continue. After seven days of disconnected use, you will be reminded about the requirement to connect to the Internet. An Internet connection is required in order to access cloud services.
if thats the case you may want to look at perputual licensing which doesn't require internet connection only for activation
DarrenP
