AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD LT Launch problem
6 REPLIES 6
sergej_dezelak
436 Views, 6 Replies
I have problem when I launch AutoCAD LT, I got this message (image LT1). It apear only when I first launch my PC, if I restart PC, than it is ok. I use Windows 8.1.
Second problem is (image LT2), this message apear at launch AutoCAD LT. Do you think it is problem only with graphic card?
6 REPLIES 6
rkmcswain
in reply to: sergej_dezelak
Not sure when else can be said about image LT2. It pretty much says it all in the dialog. Your video card does not support hardware acceleration.
R.K. McSwain     | CADpanacea | on twitter
braudpat
Hello
Please you are speaking of which LT version : 2015, 2014, 2013, etc ?
Which graphic card on your PC ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
sergej_dezelak
in reply to: braudpat
Its LT version 2014, but before there was no problem, last month this message apear.
the graphic card is:
NVIDIA Quadro K4000M
pendean
What changed last month? Both messages are informative and provided you with options: what's the challenge here exactly?
sergej_dezelak
in reply to: pendean
I just want to know why this message apear.
pendean
Your first message appeared because, according to it, you ran a Windows Registry Cleaner in WIndows. Or an application on your PC did. AutoCAD didn't do it, it's just letting you know that's a probably cause.
The second message appread because your video card driver changed: AutoCD didn't do that either. it's just telling you your system change is changing how AutoCAD uses your system.
So what changed a month ago? find out, even Windows will tell you.
”Boost
