AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Autocad LT drawings into CNC programs
8 REPLIES 8
Message 1 of 9
8186 Views, 8 Replies
Can anyone tell me how or where to go to find out how to convert Autocad LT drawings into programs our CNC machining centers can use? Autocad assured me it would do this when we bought it. I just can't seem to find any info on it.Thanks
8 REPLIES 8
Message 2 of 9
What file format do your CNC machining centers need?
Dean Saadallah
www.pendean.com
"barryfmi" wrote in message
news:f0b2938.-1@WebX.maYIadrTaRb...
it.Thanks
Message 3 of 9
I'm told they use text file format. We currently use ProComm Plus for communications. MS-Dos text with line breaksis their favorite.
Message 4 of 9
Message 5 of 9
All DXF files are text files, which version is likely to be supported you
would need to find out. R12DXF, using the SAVEAS command, is as low as you
go, and tends to be compatible with most programs that claim DXF
compatibility.
Dean Saadallah
www.pendean.com
news:f0b2938.1@WebX.maYIadrTaRb...
Message 6 of 9
Barry,
You cannot convert AutoCAD drawings into CNC programs without using
additional software which takes the drawing geometry and creates the
corresponding NC instructions (which differ from machine to machine).
You need (and probably have) an NC-generation program. To transfer
your drawings into this programming system, you will use a file format
both programs (AutoCAD and the NC-programming system) know. This could
be DWG, but it is very liekly that it's DXF. Every NC-programming
system in the world can read DXF files, but you may need to experiment
a bit about which version of DXF works best. You select the DXF
version to write using AutoCAD's saveAs or DXFout dialogs.
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
Message 7 of 9
Well Barry,
I believe Autodesk must have miss led you... We here also use a CNC machine to generate parts. We have to draw the parts, export them in DXF form, and then put that file into another program (we use Mastercam) to create the NC code for the machine. If AutoCAD generated the NC code we would not have bought the extra $8000 in software from mastercam...
Message 8 of 9
use turbonest software (hyperthrm)
for 2d autocad drawing to cnc (funuc) programme
Message 9 of 9
”Boost
