Hi!
We made upgrade from 2 Land 3 NLM to Autocad LT 2015 NLM.
We have the license file but we can´t install Autocad LT as NLM.
How can we install Autocad LT 2015 network version?
Is there a special link to download the msi?
We already have the license file…
Changing the registry does not work any longer
Solved by philip.s. Go to Solution.
Hi have a serial number with 2 licenses of Autocad LT 2015.
I can´t authorize it because they rae NLM licenses. Autodesk send me a license file to configure the redundant servers.
How can i run the Autocad LT ?
Please, check attached image. Printscreen from Autodesk PartnerCenter
Have you see the atached image?
Is a printscreen from the Autodesk PartnerPortal - License Inquiry
There you can see that this Autocad LT 2015 are NLM (Network) and Autodesk already send us the license file (.lic) to configure LMTOOLS.
I´m 100% sure that Autodesk have a Autocad LT 2015 NLM Deployment i just don´t have it.
If you would, plesase, check it for me i would be mutch apreciated.
If this helps: Autodesk Support CaseNo:09965555
Another person that alreay saw LT NLM deployment (i checked in subscription center, under donwloads/extras and therer´s nothing there...)
http://forums.autodesk.com/t5/autocad-lt-general-discussion/lt-2015/td-p/4900618
Regards
Manuel Moreira
ITEN Solutions
Autodesk Gold Partner
Hi Manuel,
Just to confirm, we do offer a networked version of AutoCAD LT which is typically reserved large enterprise applications.
As such, I've just sent you a Private Message with the corresponding 2015 download links. Please let us know if there is anything else that we can assist with!
