Opened a legacy drawing into Autocad LT 2015 that shows multiple text and dim leaders appearing to not be associated with anything and covering my drawing workspace. What is the cause of this.
Solved by bryce.thelin. Go to Solution.
nothing 😞
Do you have Dropbox or Microsoft OneDrive or similar you can use instead to share your file?
Can you email me the attachment to moderator@autocad.com.
I'll attempt to attach it for you. If i can then we'll try to figure out why you can not
Discussion_Admin
I have Dropbox, but with whom am I sharing it with? I have also attached the .dwg file with this notice. Perhaps there is a problem with my attempt to attach the file. Once I do, it shows up below as an attachment; then I select Post.
Hi Ronny,
For the problem that you described, if it is what I think, try changing the variable LINESMOOTHING in AutoCAD to Off. Let us know if that helps.
