AutoCAD LT Forum
AutoCAD LT 2015 graphic glitch and slowdown + HP long print time
4 REPLIES 4
davor
609 Views, 4 Replies
I have noticed a graphic glitch and intense slowdown in AutoCAD LT 2015 when moving cursor in model space on several laptops.
Screen shot is attached below.
System specifications on laptops are:
i5 processor family
4 to 8 Gb of RAM
ATI 8xxxM and Nvidia GT620M graphic cards
OS: Windows 7 64 bit
Also printing on HP Business Inkjet 2800 takes around 2 minutes to even start printing.
Does anyone maybe know a solution to those problems?
4 REPLIES 4
rkmcswain
in reply to: davor
pendean
in reply to: davor
or... turn off LINESMOOTHING variable and possibly even LINEFADING variables in LT2015, then change hardware acceleration settings in LT2015 and see if that can help even more.
none of the tips address your printing issue: does plotting to another device or driver also remain slow too? Are you connected wirelessly to it? Did you make the mistake of "migrating' from an earlier LT version when you installed or first started LT2015? Are you plotting to the HP's system driver or a PC3 file you all created and share?
davor
in reply to: rkmcswain
Ty, I will test and report back.
DarrenP
in reply to: davor
also may want to try the Autocad 2015 SP 1 beta
http://autodesk.blogs.com/between_the_lines/2014/05/beta-test-the-autocad-2015-service-pack.html?utm...
this covers both autocad 2015 and autocad lt 2015 and nothing else
DarrenP
”Boost
