AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Autocad LT 2015 Crashes when clicking on the Icon
2 REPLIES 2
592 Views, 2 Replies
To All,
           I am using Autocad LT 2015 and was working fine until this morning.
I cannot boot up the software with out receiving the error message shown in the
attachment.
The following are the unsuccessful attempts to fix the problem:
  • Removed Windows Internet Explorer 11 and all the updates per Autodesk Knowledge Network Standalone Lcense Wizard Crashes.
  • Repaired Autocad LT 2015
  • Reinstalled Autocad LT 2015
No luck. Can you help ?
Best Regards,
John
2 REPLIES 2
pendean
Windows System Restore back to a week or month it all worked should be the first thing to always do in similar circumstances. May not be too late to try.
in reply to: pendean
Hi Dean Saadallah ,
      Thanks for the info but did not solve the problem. The problems is with Windows DLL's not starting.
Got help from a local Autodesk provider with the following link to install Windows Autoruns which allowed
to turn off the DLL's causing the problem.
Here are the links in case someone else reads this and has the same issue:
http://upandready.typepad.com/up_and_ready/2014/03/autocad-2015-application-error-0xc0000142-autorun...
http://technet.microsoft.com/en-ca/sysinternals/bb963902.aspx
Best Regards,
John
”Boost
