I recently installed the software AutoCAD LT 2014.
When I do a save/saveas, it crashes and creates a .tmp file and when I open the recover file, I get this message 'Unable to load profile file. Some profile information saved in the last session may not be restored.'
No ribbons or my profile is loaded, all custom commands restore back to default, have to manually bring out my toolbars that I normally use on a daily like my Layer and Properties windows.
I can't copy blocks or anything from another drawing into the drawing I am on, ctrl c is unresponsive.
Welcome to the Autodesk Forums!
First thing is to shut down and do a hard reboot. You never know.
Try a Repair Install if you have the disk to see if that will clean up your issues.
Or download and run the installer again. I will assume this will ask to do a repair install this way.
Next more drastic measures:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Remove all .NET and C++ installs from your machine.
Reinstall and open for the first time as an administrator on your machine.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
This is the error message I've seen when I first installed the trial version for CAD 2014. Same now when I'm trying to install LT 2014.
Hi Edith!
Per the following Warning 1946 solution, "This is a known issue not only in Autodesk products. This error may occur due to several factors and seems to be random in its appearance. We are looking into preventing the issue in the future. Click OK and continue with the installation. This error will not adversely affect the installed application."
I have yet to find a solution. I did everything in the previous posts of what I should do, still the same problem.
I reinstalled CAD LT and used it fine one time until i had to reopen CAD about an hour later. A message of unable to restore my previous session.....etc.
Do I need to call customer service at this point?
I rather return the software and find something else similar to CAD if this cannot be fixed.
What are your suggestions?
Installing the materials library because i left it to download on my computer while I stepped away, Is downloadin the library an issue? So you are saying I don't need it at all?
