AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCad LT 2014
15 REPLIES 15
Message 1 of 16
762 Views, 15 Replies
AutoCad LT 2014
I recently installed trial version of autocadLT 2014 which did load and apparently It worked. For some reason stopped working was advised by autodesk sales to remove and reinstall,then of course I was told can not do that. So I purchased from reseller,whom they are pretty useless. When installing software asks for serial and product key which I type in. Install button on bottom right side never highlights yet green check mark ins highlighted on top left. (not sure what that means) Finally get some from reseller told me to register product which I attemped too. But it asks for activation code which I never get.So I am stll in same boat ecept now I have purchased software that I can not install. Any help would be appreciated
15 REPLIES 15
Message 2 of 16
Charles_Shade
Welcome to the Autodesk Forums!
Likely uou need to start from a clean install.
If it has only been a few days or so since this started then try a System Restore back to prior to the first install. This should effectivley remove any Autodesk remnants from your system.
If you would prefer you can follow this advise from Autodesk to remove the software for a clean install:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
You are also entitled to free installation help form Autodesk and there should be a report generated with an email when the install crashes. Support options: (Up and Ready is your first choice)
Support Offering: (click the tabs for options)
http://usa.autodesk.com/support-offerings/basic/
Licensing and license tranfer tips and help are at:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18221949&linkID=9240617
Autodesk support is now on Twitter 24/5 (@autodeskhelp): https://twitter.com/AutodeskHelp
With a blog: http://blog.autodeskhelp.com/
Up & Ready Installation and Startup Help (free for new installs):
http://usa.autodesk.com/support-offerings/up-and-ready/
Safety Net / Per Incident Autodesk support (not free):
http://usa.autodesk.com/support-offerings/per-incident/
If you are on subscription, visit your Autodesk Subscription Page for direct Autodesk Help:
http://www.autodesk.com/subscriptionlogin
Contact a Reseller for support (not free):
http://www.autodesk.com/reseller
Customer Error Reporting:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7047344&linkID=9240617
You mentioned using a reseller and that they have been less than helpful. Is this an Autodesk authorized reseller or an office supply store from some place like Amazon?
If it is an Autodesk reseller print their name here in bold 20 point lettering. Autodesk needs to know if thier authorized resellers are not doing thier job.
Message 3 of 16
Okay Charles
I'll try it. Hopefully it will work been very brutal
Message 4 of 16
Charles
was not able to startat an earlier date. Apparently when my computer was in for service they left restore button disabled. Was able to go into registry editor and remove Autodesk from local machine,but unable to remove from current user. I am able to delete but when I reboot computer its back. Cannot get to support after I put serial # and product key next screen install button does not highlight.
Name of Reseller is PC CONNECTION
If they would have told me from the beginning they could not help with install. Would not have purchased.Which I will be stopping payment tomorrow if I can not get this resolved.
Message 5 of 16
pendean
You seem to have a system level issue: I suspect no other reseller is going to be able to help until you resolve it.
Start with a Windows System Restore back to a date before the original Trial version.
Uninstall any remaining Visual C++ apps.
Restart PC.
Disable Windiws automatic updates for ever.
Disable all background running apps then try a reinstall.
If that fails you are looking at a more dramatic OS reinstall.
PS: buying from PC Connection is like buying from Walmart. They don't understand or get it or have to get it. They just sell it: you must seek help from Autodesk from the links Charles provided above.
Message 6 of 16
Bob_Zurunkle
in reply to: pendean
OP are you on a subscription? If not then you should consider doing so. Investigate the benefits...
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 7 of 16
in reply to: Bob_Zurunkle
So I guess I am still no where with this. Pretty disgussed with this whole fiasco. When I install disk get to where serial number / product key. to next screen where I have the option to install but cannot due to being greyed out. So I can not get an activation code. Any way I can get activation code by phone. It appears that free trial caused all these issues. Other than me formating my computer is there any other way
Message 8 of 16
Just for the heck of it went unto autodesk site and downloaded a free trial of full version of AUTOCAD 2014. How does this work and a buy a license and it doesn't work.
Message 9 of 16
Sorry for long delay in response. Attached is screen shot of how far I get with install. Notice install button does not highlight for me to install. So I cannot get a request code.
As wanted to see if my machine was the problem. So I went onto autodesk site and downloaded trial of full version.To my surprize it downloaded and I was able to open it and view drawings (this was only a test)
Not sure if I need to remove before licensed autocadlt gets on machine.
serial # 378-81823537
product key 057F1
FYI I also contacted PC Connection where software was purchased from and as I found out they do not offer support,but they also added neither does any other reseller, which at this point I don't care would just like to get this to work.
e-mail jerry@advancedbuildingcontrols.com
cell 201 954-4731
home 908 441-2694
Message 10 of 16
dgorsman
Thats not entirely correct, and sounds like somebody is covering their posterior.  We get a lot of support from our reseller; in fact, when we submit support cases through the Subscription center our reseller takes point during the process.  Not all resellers do this, its one of those extra things to look at when shopping around for one.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 11 of 16
in reply to: dgorsman
I am just relaying what I was told by them. As far as I am concerned they
should even be on your reseller list. I just want it to work
Message 12 of 16
Is it possible to get this software to work
Message 13 of 16
pendean
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24 is for Installation help. Link your post there to this one.
Message 14 of 16
I signed in using my school e-mail for a student version serial number and product key for AutoCad LT 2014
 serial number is good but the product key doesn't work.
Message 15 of 16
in reply to: Charles_Shade
Message 16 of 16
Charles_Shade
AutoCAD LT 2014 Product key:
057F1
Though if this is a free dowload from the Autodesk Education Community then AutoCAD LT is not available.
Are you trying to get the Full version of AutoCAD or some other LT variant?
Please see the link for all the Prodcut keys of 2014 offerings:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21481916&linkID=12305695
”Boost
