AutoCAD LT Forum
AutoCAD LT 2014 won't install.
5 REPLIES 5
dirks12
2484 Views, 5 Replies
I bought today a license for Autocad LT 2014 but unfortunately it won' t install. Please see my error log which is attached.
system specs:
MS 7 64 bits
IntelXeon e5-2620 @ 2 ghz, 16 GB ram, nvidia quadro 4000
Does anyone know how to fix this direct runtime problem?
Dirk
5 REPLIES 5
pendean
in reply to: dirks12
Uninstall all instances of .Net Framework
Do the same for Visual C++
Restart Windows.
Reattempt the installation. Then run Windows Update and force it to do a manual search for updates so that it can reinstall those we removed at the beginning.
If that failed, search around these forums where you are posting for ERROR RESULT=1618 and ERROR RESULT=1619
dirks12
Thanks for your input.
I removed Visual C++ and all .NET framework, cleaned %temp% , rebooted and did the installation again.
Unfortunately the installation failed 😞
For your information I've attached my errorreport.
You' ve asked me to look for ERROR RESULT=1618 and ERROR RESULT=1619 in this forum., I cannot see the wood for the trees 😞 , it is me too technical...
Thanks for you input.
Dirk
pendean
Yes, a new unch of error messages have appeared now: are you logged in as full adminitrator?
Are you trying to install LT from a disk, or online?
dirks12
in reply to: pendean
I'm trying to install from disk (dvd) as an admin.
Charles_Shade
Type 1618 into the search function in this blog:
http://upandready.typepad.com/up_and_ready/
Also since this is a new purchase have Autodesk do a little work you:
http://usa.autodesk.com/support-offerings/up-and-ready/
And we are end users like yourself so installation help can be a little frustrating on this end.
You may aso want to try:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
”Boost
