Can I install the AutoCAD Plant 3D 2014 Object Enabler on a trial version of AutoCAD LT 2014?
We have the AutoCAD LT 2014 trial version installed, but when I tried installing the 3D Object Enabler, it didn't recognize that there was an Autodesk product currently on the computer. It said that an Autodesk product had to be installed first before installing the enabler.
To answer your question if the OE supports LT2014, the answer is no (I think :-)). However, other companies that we work with were able to install this OE on LT2014.
ask them how they go it to work
DarrenP
I would love too, but they are our competitors and doubt they would divulge information that could give us the upper hand. Basically we are trying to determine if the LT2014 version will give us the capabilities to do what we need it to do rather then having to buy the full version.
I appreciate your snarky response, but my leg is not being pulled. Just spoke with a guy and he assured me that it should work, so his advice was to try a previous version of the OE.
Can't say I see Plant 3d OE for LT 2014:
There is a Plant 3D OE for AutoCAD Full but as was said this will not install on LT.
Check your leg again and make sure you are talking all apples with the "guy".
Sounds like they are trying to keep that leg up on you.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I'm less of a "black helicopter" guy. I'm thinking that they have Plant3D and/or vanilla AutoCAD installed on those computers, either in place of or in addition to LT.
Something to ask?
