We installed Autocad LT 2014 on many computers, updating from 2011 without any problems except on 1 where the installs rolls back by itself without error message.
Here is the end of the install log:
Property(S): _D3843F78EC3649109DC42110F239CDE8.3F01C84C128B435388396793A7DC8B99 = C:\Program Files\Common Files\Autodesk Shared\AdLM\R7\
Property(S): _DD68F369220E4C299CD095CC4192F54E.3F01C84C128B435388396793A7DC8B99 = C:\Program Files\Common Files\Autodesk Shared\AdLM\
Property(S): NEWRETARGETABLEPROPERTY2.3F01C84C128B435388396793A7DC8B99 = C:\Program Files\Autodesk\AutoCAD LT 2014\
Property(S): _D13E016E512F43759F7E80D6EDB212B3.3F01C84C128B435388396793A7DC8B99 = C:\ProgramData\Autodesk\AdLM\
Property(S): _0BB6AACB96A84B71AFC740A84C0747F3.3F01C84C128B435388396793A7DC8B99 = C:\ProgramData\Autodesk\AdLM\R7\
Property(S): _31611888AAEC44D3ADC83201A623C177.3F01C84C128B435388396793A7DC8B99 = C:\Program Files\Common Files\Autodesk Shared\AdLM\R7\imageformats\
Property(S): CommonFiles64Folder.3F01C84C128B435388396793A7DC8B99 = C:\Program Files\Common Files\
Property(S): _E383CE72CE234846A78EB52B94CD56EA.3F01C84C128B435388396793A7DC8B99 = C:\Program Files\Common Files\Autodesk Shared\
Property(S): NEWRETARGETABLEPROPERTY1.3F01C84C128B435388396793A7DC8B99 = C:\Program Files\Autodesk\AutoCAD LT 2014\
Property(S): COMMONAPPDATA.3F01C84C128B435388396793A7DC8B99 = C:\ProgramData\
Property(S): _4C9B7403F8704E13B3AF1D2E7539FF4A.3F01C84C128B435388396793A7DC8B99 = C:\ProgramData\Autodesk\
Property(S): adlmInstSetProductInformation = 057F1;057F1;2014.0.0.F;\\SERVER***\Logiciels\005-AutoCAD\Autodesk 2014\ACLT_64\Img\x64\acadlt\AutoCADLTConfig.pit;393-67315189;1;1;CH
Property(S): fnpActSvcInstall = Autodesk;AutoCAD LT 2014 - Français (French);
Property(S): ProgramCompanyDir.D01EB5D5_0EC4_4BDF_A131_1989F9F14A91 = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\
Property(S): ProgramMenuFolder.D01EB5D5_0EC4_4BDF_A131_1989F9F14A91 = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): ProgramFilesFolder.D01EB5D5_0EC4_4BDF_A131_1989F9F14A91 = C:\Program Files (x86)\
Property(S): CommonFilesFolder.D01EB5D5_0EC4_4BDF_A131_1989F9F14A91 = C:\Program Files (x86)\Common Files\
Property(S): AutodeskShared.D01EB5D5_0EC4_4BDF_A131_1989F9F14A91 = C:\Program Files (x86)\Common Files\Autodesk Shared\
Property(S): R1.D01EB5D5_0EC4_4BDF_A131_1989F9F14A91 = C:\Program Files (x86)\Common Files\Autodesk Shared\Uninstall Tool\R1\
Property(S): UninstallTool.D01EB5D5_0EC4_4BDF_A131_1989F9F14A91 = C:\Program Files (x86)\Common Files\Autodesk Shared\Uninstall Tool\
Property(S): SETUP_ISLANGUAGEPACK = 0
Property(S): SETUP_UNINSTALLKEYS = 1
Property(S): ADSK_PRECALC_FILECOST = 1
Property(S): ADSK_PATCH_STATE = 3
Property(S): MsiLogFileLocation = C:\Users\DCI~1.SCH\AppData\Local\Temp\AutoCAD 2014 Install.log
Property(S): ADSK_INSTALL_TYPE = Custom
Property(S): ACAD_TEMP_CADMGR_DISPLAY_NAME = Canal du gestionnaire CAO
Property(S): ADSK_EULA_STATUS = #1
Property(S): ADLM_LICENSE_TYPE = #3
Property(S): MUILANG = fr-fr
Property(S): SETUP_PACKAGENAME = Autodesk® AutoCAD® LT 2014
Property(S): SETUP_PACKAGECODE = {D54FD115-F651-4237-B57C-E4230340EAB6}
Property(S): SETUP_PRODUCTDEPENDENCIES = Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.0,.NET Framework Runtime 4.0 Language Pack,.NET Framework Runtime 4.0 KB2468871,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{644F9B19-A462-499C-BF4D-300ABC2A28B1},{51BF3210-B825-4092-8E0D-66D689916E02},{62F029AB-85F2-0000-866A-9FC0DD99DDBC},;{5783F2D7-D009-040C-2102-0060B0CE6BBA},{52B28CAD-F49D-47BA-9FFE-29C2E85F0D0B},;;
Property(S): PackageCode = {C3F2CADF-C143-4F12-B4A2-81030DFD291B}
Property(S): TRANSFORMS = \\SERVER-L12\Logiciels\005-AutoCAD\Autodesk 2014\ACLT_64\Img\x64\fr-fr\acadlt\acadlt.mst;\\SERVER-L12\Logiciels\005-AutoCAD\Autodesk 2014\ACLT_64\Img\x64\acadlt\acadlt-AutoCAD LT.mst
Property(S): ProductState = -1
Property(S): PackagecodeChanging = 1
Property(S): ADSK_SOURCE_ROOT = \\SERVER***\Logiciels\005-AutoCAD\Autodesk 2014\ACLT_64\Img\
Property(S): ADSK_SETUP_EXE = 1
Property(S): CURRENTDIRECTORY = C:\Users\DCI~1.SCH\AppData\Local\Temp\_AI219D.tmp\Setup
Property(S): CLIENTUILEVEL = 3
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTPROCESSID = 7088
Property(S): MsiSystemRebootPending = 1
Property(S): VersionDatabase = 200
Property(S): VersionMsi = 5.00
Property(S): VersionNT64 = 601
Property(S): WindowsBuild = 7601
Property(S): ServicePackLevel = 1
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): WindowsVolume = C:\
Property(S): RemoteAdminTS = 1
Property(S): ACAD_INSTALLDIR = C:\Program Files\Autodesk\AutoCAD LT 2014
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): MsiAMD64 = 6
Property(S): Msix64 = 6
Property(S): Intel = 6
Property(S): PhysicalMemory = 8147
Property(S): VirtualMemory = 13936
Property(S): AdminUser = 1
Property(S): MsiTrueAdminUser = 1
Property(S): LogonUser = dci
Property(S): UserSID = S-1-5-21-989151510-2321782987-822362055-1173
Property(S): UserLanguageID = 4108
Property(S): ComputerName = PC23B
Property(S): SystemLanguageID = 4108
Property(S): ScreenX = 1024
Property(S): ScreenY = 768
Property(S): CaptionHeight = 22
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): TextInternalLeading = 3
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 16:27:41
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
Property(S): RedirectedDllSupport = 2
Property(S): MsiRunningElevated = 1
Property(S): Privileged = 1
Property(S): DATABASE = C:\Windows\Installer\1eb9b7a.msi
Property(S): OriginalDatabase = \\SERVER***\Logiciels\005-AutoCAD\Autodesk 2014\ACLT_64\Img\x64\acadlt\acadlt.msi
Property(S): UILevel = 2
Property(S): MsiUISourceResOnly = 1
Property(S): ACTION = INSTALL
Property(S): DGNFILEASSOC = 0
Property(S): ACADNETSCAPELOCATION = o
Property(S): LOCAL_INSTALLDIR = C:\Program Files\Autodesk\AutoCAD LT 2014
Property(S): ACAD_PersonalFolder = C:\Users\dci.SCHERLERLSDOM\Documents
Property(S): RDF_SUB_DIR_0images = C:\Program Files\Autodesk\AutoCAD LT 2014\Support\fr-FR\WelcomeScreen\images\
Property(S): RDF_SUB_DIR_0css = C:\Program Files\Autodesk\AutoCAD LT 2014\Support\fr-FR\WelcomeScreen\css\
Property(S): CostingComplete = 1
Property(S): SourcedirProduct = {5783F2D7-D009-0000-0102-0060B0CE6BBA}
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 480516384
Property(S): PrimaryVolumeSpaceRequired = 1391058
Property(S): PrimaryVolumeSpaceRemaining = 479125326
Property(S): PrimaryVolumePath = C:
Property(S): TEMPFILE_INSTALLDIR = C:\Users\DCI~1.SCH\AppData\Local\Temp\ad4C83.tmp
Property(S): ACADSECURITY = VS
Property(S): ProductToBeRegistered = 1
=== Arrêt de l'enregistrement:29.04.201416:27:41 ===
MSI (s) (F8:5C) [16:27:41:753]: Note: 1: 1708
MSI (s) (F8:5C) [16:27:41:753]: Transforming table Error.
MSI (s) (F8:5C) [16:27:41:753]: Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (F8:5C) [16:27:41:753]: Produit: AutoCAD LT 2014 - Français (French). --L'opération d'installation a échoué.
MSI (s) (F8:5C) [16:27:41:753]: Windows Installer a installé le produit. Nom du produit : AutoCAD LT 2014 - Français (French). Version du produit : 19.1.18.0. Langue du produit : 1036. Fabricant : Autodesk. Réussite de l’installation ou état d’erreur : 1603.
MSI (s) (F8:5C) [16:27:41:753]: Attempting to delete file C:\Windows\Installer\1eb9b7b.mst
MSI (s) (F8:5C) [16:27:41:753]: Unable to delete the file. LastError = 32
MSI (s) (F8:5C) [16:27:41:753]: Attempting to delete file C:\Windows\Installer\1eb9b7c.mst
MSI (s) (F8:5C) [16:27:41:753]: Attempting to delete file C:\Windows\Installer\1eb9b80.mst
MSI (s) (F8:5C) [16:27:41:753]: Attempting to delete file C:\Windows\Installer\1eb9b81.mst
MSI (s) (F8:5C) [16:27:41:769]: Deferring clean up of packages/files, if any exist
MSI (s) (F8:5C) [16:27:41:769]: Attempting to delete file C:\Windows\Installer\1eb9b7b.mst
MSI (s) (F8:5C) [16:27:41:769]: Attempting to delete file C:\Windows\Installer\1eb9b7c.mst
MSI (s) (F8:5C) [16:27:41:769]: Attempting to delete file C:\Windows\Installer\1eb9b80.mst
MSI (s) (F8:5C) [16:27:41:769]: Unable to delete the file outside of the engine. LastError = 2
MSI (s) (F8:5C) [16:27:41:769]: Attempting to delete file C:\Windows\Installer\1eb9b81.mst
MSI (s) (F8:5C) [16:27:41:769]: MainEngineThread is returning 1603
MSI (s) (F8:04) [16:27:41:769]: RESTART MANAGER: Session closed.
MSI (s) (F8:04) [16:27:41:769]: No System Restore sequence number for this installation.
MSI (s) (F8:04) [16:27:41:769]: User policy value 'DisableRollback' is 0
MSI (s) (F8:04) [16:27:41:769]: Machine policy value 'DisableRollback' is 0
MSI (s) (F8:04) [16:27:41:769]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (F8:04) [16:27:41:769]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (F8:04) [16:27:41:769]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (F8:04) [16:27:41:769]: Restoring environment variables
MSI (s) (F8:04) [16:27:41:769]: Destroying RemoteAPI object.
MSI (s) (F8:94) [16:27:41:769]: Custom Action Manager thread ending.
MSI (c) (B0:A8) [16:27:41:769]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: 0
MSI (c) (B0:A8) [16:27:41:769]: MainEngineThread is returning 1603
=== Verbose logging stopped: 29.04.2014 16:27:41 ===
You are getting a fairly common 1603 error.
Check out the 1603 error links in the signature line of TravisNave:
http://forums.autodesk.com/t5/Installation-Licensing/invalid-serial-number/m-p/3393445#M44015
