when I use geomap view i will se satelitte picutres of the area I am viewing, but certain areas over my hometown in which I work (Eskilstuna, Sweden) are blank, this has not always been the issue is there a local cache of some sorts that I could clear ?
That is not an installation question, you are posting in the wrong forum. LT has a dedicated forum for usage type questions: http://forums.autodesk.com/t5/AutoCAD-LT-General/bd-p/43
Are you logged into Autodesk 360? Required I believe. Also, 99% of the time black maps means someone somewhere wants you to pay for access or those regions are 'off-limits'. See below, I can see everything I presume.
