Stretch command is dependent on how you select your object to stretch.
It's called a stretch frame, everything inside the stretch frame will be moved, everything partly covered will be stretched.
attached you can see it used in a DynBlk as a quick example.
did u install anything else in addition to LT?
I have been using Autocad LT2004. Stretch works differently in LT2004 than in LT2013. I was selecting the whole object. Now I see how it works.
Thanks a lot
vadakem
Stretch works the same.
It is likely a Variable or Selection mode that was not the same as you had it set in the LT 2004 program.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
