Does anyone know if the versions of autocad listed in the subscription download center are just the original version or are they updated versions throughout the year with the product enhancements?
I see 2014 is about to come out and i see no enhancements
except a community command plugin that came out in 2010 and will not even work
thanks Jim
Solved by Charles_Shade. Go to Solution.
What will be listed on the Subscription site are the first released versions.
If Updates or Service Packs are needed these will be issued seperately and will need to be installed to the Version that has been downloaded.
Many wait for the first Service Pack to be released prior to putting a new Version into full production.
Beta testing and the release of the Version to 100 fold more users will find problems that need to be adressed.
You can always find all the Updates and Service Packs for the LT product line here:
http://usa.autodesk.com/adsk/servlet/linkedsumindex?siteID=123112&id=2334430&linkID=9240818
From the Community Command Plug-in: http://subscription.autodesk.com/sp/servlet/download/item?siteID=11564774&id=14714082
Supports AutoCAD 2010 and 2011 (32-bit and 64-bit).
I doubt that this feature will be a part of new software releases since it is three versions behind now. And the System Requirement link is broken.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
