Please can someone help me, I've got a toolbar macro to select objects and to flatten them as seen below :-
^C^C_select;auto;\_move;p;;0,0,0 0,0,1e99;_move;p;;0,0,0 0,0,-1e99
but when I run it it hangs thus :-
Command: _select
Select objects: auto
Select objects: Specify opposite corner: 2 found
Select objects:
Command: _move
2 found
Specify base point or [Displacement] <Displacement>: p
Point or option keyword required.
I have searched for solutions but all I get is the macro I'm already running.
I am using Autocad 2013 Lt.
Thanks in advance
Solved by pendean. Go to Solution.
All I can say is to double check the macro in the cui. I did a copy paste of the macro you have in your post and it worked fine. I running 2014 but that shouldn't make a difference.
