AutoCAD LT Forum
AutoCad LT 2013 Error Message
2 REPLIES 2
bbacoyiannis
1106 Views, 2 Replies
OS is Windows 7 Enteprise SP1 French
AutoCad LT 2013 installed in french
Running the app with admin priviligaes works fine, but as a standard user we get the following error.
Erruer 1324. Le chemin du dossier "My Pictures" contient un caractere invalide.
Any ideas?
Thanks , I add a screenshot as welll
2 REPLIES 2
Have you started the Seat of LT on the Standard users System as an Admin first, shut down LT, logged off Admin, logged on as Standard User and then tried the LT?
Or doe this have something to do with the Program while it is running?
ITK-Admin
in reply to: bbacoyiannis
We had the same error with Autocad 2012 LT (in german  "Fehler 1324. Der Ordnerpfad "Eigene Bilder" enthält ein ungültiges Zeichen.") first starting Autocad.
This Autocad error is caused in our case in a folder redirection policy in active directory (for example "\\server\home\userXY\Eigene Bilder").
A workaround is to edit the registry key "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders\My Pictures" to a path like "C:\temp" or a variable like "%USERPROFILE%". After Autocad was started successfully you can change it back.
”Boost
