AutoCAD LT General Discussion
Member
0 Kudos
Post 1 of 4
AutoCAD LT 2013 Dynamic Block Issues - Visibility States
673 Views, 3 Replies
04-11-2012 02:05 AM
I have made up an extensive dynamic block library over the year, however in the latest version when I have tried to modify blocks with visibility states you can not cycle through the different states it will just revert back to the first one. has anybody had the same issues and is there a work around?
Valued Contributor
0 Kudos
Post 2 of 4
Re: AutoCAD LT 2013 Dynamic Block Issues - Visibility States
04-11-2012 07:10 AM in reply to: aallan
Yes, I discovered this last night on my laptop. Tried it again on my work computer and the same thing occurs there too.
Valued Contributor
0 Kudos
Post 3 of 4
04-12-2012 07:20 AM in reply to: aallan
I turned off the property preview and it seems to work now. Go to Options, Selection, Property preview. I have them all turned off.
Member
0 Kudos
Post 4 of 4
04-12-2012 09:05 AM in reply to: aallan
Thanks that has sorted the issue for me too.
Post to the Community
New Post
