AutoCAD LT General Discussion
New Member
cemexni
Message 1 of 4 (3,036 Views)
AutoCAD LT 2013 - Crashes at startup
3036 Views, 3 Replies
10-15-2012 02:53 PM
AutoCAD LT 2013 - Crashes at startup and haven't been able to use at all!
Autocad opens and them it closes itself very quick. It doesn´t give me any error. The program was running ok, until last week. Haven´t make any system changes
I´ve tried to uninstall and them install de program, reinstall :NET framework and still nothing
Please help
Charles_Shade
Message 2 of 4 (3,013 Views)
Re: AutoCAD LT 2013 - Crashes at startup
10-16-2012 05:01 AM in reply to: cemexni
Since you have already tried a reinstall this may not work but s System Restore to a week or more ago may correct the error.
Do you allow Windows to automatically update your system?
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
More complete .NET fix if you did not go through this procedure:
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
New Member
cemexni
Message 3 of 4 (2,997 Views)
10-16-2012 07:57 AM in reply to: Charles_Shade
Hi Charles, thanks for the reply
I removed all the autocad using the procedure you mention and using the cleanup utility for remove the .NET Framework, and still nothing.
I´m afraid the system restore is not an option for me, because is turned off in the pc.
Do you have any other ideas??
Charles_Shade
Message 4 of 4 (2,992 Views)
10-16-2012 09:05 AM in reply to: cemexni
Another place to post for Installation Errors:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
If you are not receiving any warnings make sure you re-post that as well.
