I am running LT 2012 and it keeps freezing at the Loading customiztion files point... This locks the whole pc and I need to do a hard reset. Please help...
Hello
Your ACAD LT 2012 was running before ?
Have you try to launch with an other Windows User ?
Have you try to launch with a Login Local Admin ?
Which PC ? Which Windows , Which version (32 or 64 bits) ?
Have you installed the SP 2 on your ACAD LT 2012 ?
Bye, Pat
Patrice BRAUD
What changed on your PC?
New program?
Windows update?
Registry Cleaner?
Norton products update?
New/Old problem?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I did work yesterday. luanched as other as admin whatever and no dice. installed SP2 for CAD and did system restore to 2 weeks ago. No Dice. Emachines, Windows 7 pro, Dual core pentium 3GB of ram, 32-bit system.
It will finish Boot in safe mode but won't run due to lilimted graphics...
Tried a repair install?
Do you have the LT 2012 disk? If not you may need to request the media for a repair or reinstall before doing what is below:
Two ways to start over:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
REVO UNINSTALLER The free version on its most aggressive setting will get rid of all files.
Use this as the uninstall instead of Windows.
Back up your customizations first.
Did you reboot your computer after using the REVO or Autodesk's recommendations?
If the registry is clean the LT should install.
Any error messages?
From Start, Run Programs, type in %TEMP% and clean out the Temp Folder after you have removed all Autodesk from the Registry (Assuming you are comfortable doing that. REVO will keep out of the Registry Editor).
Reboot the Computer and try the install.
There will be an Installation log generated in the %TEMP% Folder that can be used to pinpoint the issue.
If this happens again you need to go to the Installation Forum for advice.
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
